Wheel bearing V8S
You are an english-speaking person, you want to communicate with french TVR enthousiast, leave a message on the board...
Paul
Wheel bearing V8S
Message par Paul »
Hi,
I am wondering if some of you can help me.
I am stranded in Rouen with a broken wheel bearing, it is the left rear. My car is a V8S. The part comes of a Ford Sierra.
The garage the car is at, does not know how or where to obtain the part.
I am in desperate need of help and my French is terrible…
Thanks so much for your help.
Paul
Re: Wheel bearing V8S
hello Paul, i will post your message on the facebook page wich is more active than this forum
i received this adress for you:
https://aftermarket.schaeffler.fr/fr/ca ... /v-TA-1520 il faudrait pouvoir vérifier que ça soit bien ceux là 🤔 et après tout bon distributeur peut trouver sous 24h.
plasticpig1972
Message par plasticpig1972 »
The Bearing will have a ref engraved on it i think.
Autodistribution should know the reference.
I've never had a Bearing do that for sure it has been worn for a long time.
To pay for it to be repaired and the hassle imho best to get it transported to Le Havre Ferry.
I imagine you have a green card and Insured to get home.
I hope it's not the start of your Holiday.
Good luck
